Dishwasher not cleaning properly (jet?)
**Brand:GE
Model Number: ZBD8900
Main Symptom: washer inconsistently
What happens & when: I recently replaced the leaking inlet valve and sump and braided supply line. I also had a plumber replace the shutoff to the dishwasher since it was seized when I went to use it. However, the jet arms seem to not be spraying with the same intensity as they were before. I cleaned them out but they still don’t sound like they are spraying with the same force. There was no debris near the blade of the pump when I replaced the sump. Any thoughts on where to look next?
What is the complete model number?
Thanks for the response:
ZBD8900D00II
