Dishwasher not cleaning or spraying water
Brand:GE
Cafe
Model Number:CDT805P2N3S1
Main Symptom:not spraying water
What happens & when:water fills then nothing happens, then water drains
It would be recommended to check to see if there is 120 vac to the circulation pump. If there is 120 vac but the pump does not run then this will be a faulty circulation pump.
There is 120 vac to motor for 5-8 seconds then drops to 20-50 vac for 10-12 seconds. This unit has always washed like that, is that normal? I have never had any other dishwasher that washed in pulses like this has, it has never gotten dishes really clean either which I attribute to the motor not running full time during the wash cycle. thanks for help, Rick
