Dishwasher malfunctioning
Washer control panel stuck on “rinse only” and “Sani Rinse” and is doing nothing. The lights for those two buttons are blinking on and off constantly. :confused: PLEASE ADVISE !!
Note: A couple of days ago the operations panel was stuck on “Control Lock,” and one of your techs advised me to press and hold “Energy Saver Dry” and that unlocked the control board and we have been able to wash several loads of dishes since then with no hitches.
Thank You,
John5643
EM: JSDOIT2@GMAIL.COM
PH: 713-861-1644
Hi John,
Most likely the problem is a stuck pad on the key panel. The correction is to replace the control panel. If you need the correct part number, post the color of the control panel.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDS01IJBS0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Hello, I also had a blinking “Rinse Only” light so we replaced the control board. Then the “Normal” light began blinking and nothing else would work. So we replaced the control panel. It ran through the rinse cycle then stopped. Nothing works - no lights or anything. Could it be possible we blew the thermal fuse? I noticed we failed to replace the plastic shield that goes on the thermal fuse. Could that be the problem? Thanks so much!!
[QUOTE=jss91;464960]…Could it be possible we blew the thermal fuse? I noticed we failed to replace the plastic shield that goes on the thermal fuse. Could that be the problem?.. Thanks so much!![/QUOTE]
Yes, it is possible. All parts have to be installed as they were. You may want to check the thermal fuse for continuity.
Thank you Gene! Yes, that is what it was and now it is working beautifully. :smiley: Thanks again!!
You are welcome. I’m glad it’s up and running.
Model# KUDP01SLSS0
My dishwasher stopped working a few days ago. The LED lights are lit and change when I select the different cycle types but the dishwasher doesn’t start when the START button is pushed. When the dishwasher is operating properly, the LED light flashes twice after the START button is pushed indicating that the cycle will start once the door is closed. This is no longer occuring. Presently, it does not flash twice after the START button is pushed and does not start upon closing the door. Thanks in advance for any advice you have. The problem sounds similar to that of prior posts
It is possible that the problem is a bad thermal fuse. You have to check it for continuity.
The model number you posted does not come up. Verify and repost it please.
What should the desired result be when checking the fuse for continuity?
If the fuse is still good, the reading should be close to 0 Ohms.
I’m ready to replace my fuse. The directions with the fuse are poorly written. After searching the web, I believe the new fuse needs to be relocated. Where? or just farther away than the original position?
And what does the mylar shield shield against?
My questions may be premature but it seems as though the directions are written poorly to confuse the homeowner DIY-er :confused:
Did you order the new fuse?
If yes, have you received it yet?
What did you find unclear in the instructions (attached to the reply)?
The new fuse can NOT be relocated.
The purpose of the mylar shield is to insulate the thermal fuse from hot steam.
8193761 Thermal fuse installation.pdf (259.2 KB)
What I found unclear was too many instructions for such a simple job.
I do have the fuse and it was installed yesterday. So far, so good!
Everythings working!
As for relocating the fuse, I think some other info I found on the web said
move the fuse further from the original location but now I see they meant
there is a longer length of wire isolating the fuse even though it remains in the original
location.
I have a kitchenaid model KUDIo2FRSS1 that the lights just blink and want run unless you turn off the breaker for at least 30 min and then it will work for one load and do the same again, any help will be very appreciated.
You may want to start the troubleshooting from checking the door switch(es). If there is nothing wrong, replace the control board.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDI02FRSS1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
I have already checked the door switch ( the top one is the only one i could find) it tested fine so i will order the control board. Thanks for your help !
I replaced the control board and it does the same thing only now it will only work for just a few seconds instead of a full wash before the Normal light starts flashing. Although it did work for about five min the first time i turned the power on after replacing the board. Any ideas ? Thanks again
Remove the bottom panel and locate the soil sensor (#25 on the diagram). It is mounted on the sump assembly.
Unplug the dishwasher. Open the console and disconnect the keypad ribbon from the control board at P1. Plug the dishwasher back. With the door latched, disconnect and reconnect the sensor two times in less than 6 seconds.
Wait 10 seconds, then monitor the control’s response.
Listen for the dishwasher to begin filling after it concludes 5-10 seconds display test at the beginning of the service diagnostics test. If it does it, replace the control panel.
If it would not do it, the control board you installed is defective.
If you need the correct part number for the control panel, post the color of it.
Thanks, I did the test and it pumped water in and ran for about 10 min. So I ordered the control panel. I will let you know how it goes. Thanks for your help.
That took care of the problem ! Thanks for your help
