dishwasher makes a loud howling noise that progressively is getting louder. washer works fine but noise is getting worse.
You can find some useful information and/or instructions from one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/7839-whirlpool-dishwasher-makes-loud-howling-noise-during-wash-cycle.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU1200XTLB0 | AppliancePartsPros.com
[quote=Gene;99066]You can find some useful information and/or instructions from one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/7839-whirlpool-dishwasher-makes-loud-howling-noise-during-wash-cycle.html
Gene.[/quote]
Can you help guide me through how to access the motor? I have a similar problem - loud howling noise - disassembled everything I could from the inside and cleaned it all out, but still making almost a grinding noise, so I’m not sure what else to check out.
Thank you!
[QUOTE=iucpa;301094]Can you help guide me through how to access the motor? I have a similar problem - loud howling noise - disassembled everything I could from the inside and cleaned it all out, but still making almost a grinding noise, so I’m not sure what else to check out.
Thank you![/QUOTE]
What is the complete model number of the dishwasher?
How do I get to chopper? I am having the same noise problem on our Whirlpool GU1200XTLB0
The instructions are attached to the reply.
GU1200XTKQ0 tech sheet.pdf (1.1 MB)
That worked and I found what shaft holding the chopper and screen was broken. Can you tell me what part that would be for my whirlpool GU1200XTLB0?
The chopper assembly AP5983779
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU1200XTLB0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
I’ve followed the steps of removal but can’t get the inlet protector removed… Help!!!![]()
Disregard, got it. I ended up using a Paint can opener tool to snag under the edge near the screw and it finally popped up!
