Dishwasher leaking-GE Nautilus
I have a diswasher that is leaking around the door. I have replaced the following parts but that did not help.
AP2038859 (WD8X227) Tub corner baffle 1
AP2038860 (WD8X228) Tub corner baffle 1
AP3419559 (WD08X10015) Gasket 1
I am trying to decide whether to buy the complete seal around the door or just go get a new dishwasher. If I replace the seal, does it just snap in or does it need to be glued.
Any advice? Dishwasher seems to be draining fine so I can’t think of anything else that it may be.
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Door gaskets almost never cause GE dishwashers to leak. There may be a hole in the wash arm causing water to spray under the door. It may be leaking around the rinse aid dispenser. Or the most common reason dishwashers leak around the door is that the soap is creation too may suds. I see the 3-in-one action packs cause dishwashers to leak all the time if you are using them stop and see if your leak goes away. Hope this helps!! Dishwasher Repair Guide [/FONT][/COLOR][/SIZE]
