Dishwasher leaking from bottom
Dishwasher is dripping water where pump and motor are inserted. Is this an O ring problem or does the pump and motor need to be replaced?
I cannot say what is leaking.
Does sound like just a seal problem but you could check this with a flashlight and a mirror.
A mechanics mirror is handy here. It is like a dentist’s mirror just larger.
In a pinch a small mirror taped to a dowel at an angle will do the job.
I have even used one of the wife’s makeup compacts.
This should let you see where the leak is originating.
Thanks. I’ll do that
This should let you see where the leak is originating.[/quote]
