Dishwasher leak
At the conclusion of the complete cycle, water is leaking from the bottom left side of the unit onto the floor. In fact, the insulation inside the bottom-most protection panel (under the actual dishwasher) is damp. I suspect this leak is caused by either the float or the (left) tub gasket. Am I close?
Take off that toekick (access panel) run the dishwasher and see if it is leaking from underneath at the motor.
[QUOTE=abadfish66;43197]Take off that toekick (access panel) run the dishwasher and see if it is leaking from underneath at the motor.[/QUOTE]
Thanks. No leak from underneath (dry floor, motor/pump replaced last year). Leak is drip from bottom of door frame at end of cycle. Water in dishwasher empties properly (drain and pump ok?). Power of deduction: must be float and/or left/right gasket. You agree?
Try adjusting the door latch at the top of the frame, might just fix the problem.
upon closer inspection, I found that the door gasket was torn/corroded at the base of the door! I’ve ordered a new one and will install it asap. thanks…
