Dishwasher just continues to wash
This unit continues to run in the wash cycle. The only way to get it to go into next cycle is manually. I am thinking it is a control issue, but notice there are several control boards and not sure which one may be the culprit to my problem. Any help would be appreciated. :o
Hi.
Based on the info you provided the control board is bad.
For the serial number starting from 10 through 18 use part number 99003160.
For 19 and up - part number 12002709.
Here are the breakdown diagrams and Replacement parts for Maytag MDBH950AWQ DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
