Dishwasher issues
I had a dishwasher installed about a year in a half ago and it has never really worked correctly. It does not go through the entire wash cycle. It does not drain and it does not dry. Every once in a while it will complete a cycle but that is really every once in a while. I have read everything there is about what could be wrong and I have checked everything. The water temp is fine there is nothing clogged in the drain. I need help!:mad:
A Model Number may help others help you!
[COLOR=Blue]It does not go through the entire wash cycle.[/COLOR]
Need more detailed info.
Does it hang up at the same point in the cycle every time, etc?
[COLOR=Blue]It does not drain and it does not dry. Every once in a while it will complete a cycle but that is really every once in a while.[/COLOR]
I assume it drains and dries correctly when it does complete a cycle.
This tells you that the heater and the pump are OK.
[COLOR=Blue]
I have read everything there is about what could be wrong and I have checked everything.[/COLOR]
Did you remove the door’s inner panel and check the connectors and wires.
Also where the wires run from the door to under the unit.
Your problem does sound like a bad connection.
It may be a poor solder joint on the control board.
