Dishwasher internal door panel
While replacing the lower sela on the bottomof the door, I slipped and fell on the door separating the interior panel from the metal door frame. I thought I may be able to glue it with Gorilla glue but it is not recommended for polyethelene or polypropelene plastic. I’m not sure nwhat type of material the panel is made of. Any Suggestions would be appreciated.
I would use LOCTITE® PLASTICS BONDING SYSTEM
Sets in seconds. no clamps needed.
google that for more info.
[QUOTE=gerry d;868031]I would use LOCTITE® PLASTICS BONDING SYSTEM
google that for more info.[/QUOTE]
Thanks, I fixed it with a couple of bolts through the liner and frame, but I would Have more confidence with the repair with a strip bonding material between them.
