Dishwasher Help Please
I can’t get my dishwasher to start.
It will not let me select the Heavy Duty or Normal Cycles.
I can select the Quick Clean Up or Rinse Only Cycles, but when I press Start nothing happens.
The Cancel button works and all of the Options buttons work.
Prior to this the dishwasher stopped early in a cycle leaving water in the bottom of the tub.
Using information I found in this forum I was able to get the water to drain by pressing Hi-Temp Scrub - Heat Dry - Hi-Temp Scrub - Heat Dry then holding Cancel until the water was drained.
Any ideas?
Thanks.
Replacement parts for KUDU02FRSS02 models | AppliancePartsPros.com
See the attachment for the tech sheet. I could not find one for a SS02 so it is for a SS0 but should be the same.
Not sure about the second no drain symptom you listed. It would point towards a control board problem but check the keypad/control panel.
Looks like P1-4 is common to the 3 keys you list as not working.
Note that the problem may still be on the control board.
The usual way to troubleshoot this is to check the keypad and if it is OK then replace the control board. Still a bit of a crap shoot but your odds are better.
Your unit looks like it has a separate ribbon cable so that also has to be checked. I would check the keypad by disconnecting at he control board and then checking that end of the ribbon cable. Then if you find a problem check the ribbon cable.
You may want to try the following first.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
KUDP02.pdf (250.6 KB)
