Dishwasher help- not able to select cycle
Brand:Whirlpool gold
**Model Number:**GU3200XTXY3
Main Symptom:Not able to select any wash or start.
What happens & when: Happens all the time. Will only “start” if I do a reset by pressing “NORMAL, HEATED DRY ,NORMAL, HEATED DRY”. This is supposed to diagnose error but nothing is lit at the end of reset cycle.
The only cycle that I can select and starts is a draining cycle.
The issue with the dishwasher will be with the control panel. Here is a link to the part needed.
https://www.appliancepartspros.com/whirlpool-console-asm-serv-wpw10290276-ap6018806.html
Thank you! The part you linked me to says no longer available, is there an aftermarket part equivalent to it?
Unfortunately, we do not have any information on an aftermarket part for your unit.
