Ran the dishwasher as normal and was horrified to see water leaking out of the bottom of the door. Standing water will not drain out. I had to scoop all the water out with a cup to get it all out. I looked at everything I could and did not notice any hoses that were clogged. I try to start a cycle and cancel it to have it pump the water out, but it is not doing this. I’m not sure what to do next or the best way to take it apart if I am missing something else that needs to be checked.
Suck all the water out with a shop-vac and check the screens and intake to the pump. The drain pump is part 325.
Parts for GE GDF510PSD0SS / : Sump & Motor Mechanism Parts - AppliancePartsPros.com
Then see if the pump is running.
