Dishwasher has no lights on
Brand:Frigidaire
Model Number: FFCD2413US6B
Main Symptom: There are no lights on the control panel
What happens & when: Loaded the dishwasher, and it won’t run. There are no lights on (control panel). I have tried to reset the breaker.
Parts or tests already tried: Reset Circuit breaker
Check on the control board to make sure that there between 5 and 12 vdc at the P4 connector. If there is proper voltage then the issue will be the tactile board and if there is not then this will be a faulty control board.
https://www.appliancepartspros.com/frigidaire-control-assembly-5304535555-ap7218513.html
https://www.appliancepartspros.com/frigidaire-pc-board-5304535630-ap7218517.html
