I’m not knowledgeable about dishwasher, but learning fast. The filter (I believe it is) at the bottom of the dishwasher tub does not lay flat; a corner is slightly raised. This allows waste to flow through as the water recirculates. Is there a way to get it to lay flat (perhaps with clips of some sort) or do I need a new part?
Hello TonyPrince. If the coarse filter assembly is not laying flat and is warped, you will need to replace it. They do not make clips to secure it with. Hope this helps.
AP3187339
