Dishwasher fills but doesnt wash.
Bbacon, You’ll need to check voltage at the wash motor connector with a multi meter, to determine if you have a faulty motor or a faulty control board.
The attached file will assist you in tracing wires and circuits, and you’ll also be able to conduct the diagnostic cycle test.
[ATTACH]5705[/ATTACH]
DU1055.pdf (251.2 KB)
