Dishwasher Door Latch Assy - what part needs replacing?
I have a 2 yr old Kenmore/Whirlpool dishwasher (model 665.13769k602). The handle/latch on it does not have any “spring action”, feels loose, and will not lock into place (thus cannot use dw). I opened the control panel and removed the door latch assembly. There’s three plastic parts (actuator latch, latch bolt, handle) and I can’t figure out which is broke or needs to be replaced (or maybe the switch needs replacing?). Are there supposed to be springs inside (because I don’t see any), or what gives the handle that spring action feel when you pull on it with normal use?
I’m hoping this is an easy fix and I can repair myself.
I now realize how dependent I am on my dw.
Would pictures help anyone? Need more details?
[quote=afishe;111401]I now realize how dependent I am on my dw.
Would pictures help anyone? Need more details?[/quote]
[SIZE=5]I put it back together and slammed the door shut and it stayed shut, don’t know if I will be able to open it when wash cycle is done? Same problem as you![/SIZE]
I have a Whirlpool also that has the same problem. Any advice would be great. I’m unsure as to what part to order and what to do with it once I get it!
I made these repairs on a GE dishwasher, but it sounds like the same issue. Refer to this post that I made with a few photos to go along with the other posters description of the repair. Hope this helps.
http://forum.appliancepartspros.com/dishwasher-repair/516384-help-replacing-handle-actuator-spring.html#post800475
