Door gasket has deteriorated at bottom right side of door. Unit leaks.
How do I remove and replace gasket?
What is reliable source for the part?
I a repair manual available?
Just pull the old gasket out and push the new one in. You can use a little of a dish soap as a lubricant for the new gasket installation. Provide an extra 1" to 11/4" on each side to cover the bottom of the tank (for a dam to prevent leaking from splashing at the bottom corners of the tank).
Here are the break down diagrams for the Bosch dishwasher Model SHU5306 UC/12 (FD 8003-)
