Dishwasher does not dry dishes
There is no heat during the drying cycle. The element “looks” OK.
Are there thermostats or something else to look at as a culprit before I invest in a new heating element? If so what may they be and where would I locate them in the dishwasher?
I am an amateur repair guy. Would I be better off calling Maytag?
Replacement parts for DW860 models | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16007822.pdf
[COLOR=Blue]The element “looks” OK.[/COLOR]
Just because it looks OK does not mean that it is OK. Best to check it with a meter.
[COLOR=Blue]
Are there thermostats or something else to look at as a culprit before I invest in a new heating element? If so what may they be and where would I locate them in the dishwasher?[/COLOR]
See Page 3-16 in the manual
[COLOR=Blue]
I am an amateur repair guy. Would I be better off calling Maytag?[/COLOR]
Cannot say, depends on whether you have the time to repair/check it.
I’ll give it a go. Time is my best commodity.
