Dishwasher does not drain after rinse cycle
My Hotpoint dishwasher will not drain after the rinse cycle is complete. Everything else seems to work fine. Can you help?
Michael
Here is your parts
Model HDA3400G00WW
This unit just redirects the water up to the wash arms or out the drain.
Remove the kick plate
On the motor assemble left hand side you will see a solenoid this must activate for a pump out. It runs a flapper valve.
Does the valve actuate?
Does it drain partially?
Does it drain anywhere during a cycle?
