Model KUDS02SRSS0
Dispenser Door did not open in two consecutive wash runs. I ran a short load with nothing in it to insure that nothing blocked the door from opening. Door still did not function properly (3rd try). What would be the most likely problem?
Thank you!
Replacement parts for Whirlpool KUDS02SRSS0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Could be the dispenser (Item 8 In Section 2 ) needs replacing, It may have a mechanical or an electrical problem.
If you click on the part’s picture, a new page will open with more info and a Q&A section.
