Will not clean the dishes in all the cycles and their is little water residue.
Remove the lower spray arm and the pump cover. Remove the pump filter and the rinse arm assembly (#6 & #7 on the diagram) and clean them using a white vinegar and a tooth brash.
Here are the breakdown diagrams and Replacement parts for MAYTAG DWU9202AAB | AppliancePartsPros.com
Thanks Gene,I’ll give that a try and let you know what happens.
With much gratitude,
Matt
