What experience has anyone had with fixing this themselves? How would I do it? What parts would be needed?
Replacement parts for kudp02frss01 models | AppliancePartsPros.com
You need to include a better description as to:
What symptoms does it have
Is it totally dead
What is working
What is not working
Have you tried different cycle types
What have you done to diagnose the problem.
Alternatively you can replace both the keypad and control board and have a 95% chance that this will solve the problem. It is usually one of those two parts.
It started out that I could only use the heat dry and quick cycle. Then it went to just blinking to not doing anything. Just this morning I took the front panel off and it looked pretty clean inside. I then noticed when I plugged back in that the dishwasher wants to work now. So I have a load in now washing. It seems to be working. For how long, I don’t know.![]()
You may want to try the following if/when is causes trouble again
Unplug the unit
Open it up
Clean the edge connector.
