Dishwahser
not enough water coming in the tub. WHAT COULD BE THE PROBLEM? HOW CAN I CHANGE WATER PUMP/ASSEMBLY
Any Help???
You have one of two problems, LOW water pressure or dirt plugging the SCREEN inside of the inlet valve. There is no pump to put water into the unit.
