Dishwaher problems
this problem im having is very rare ,cause it works fine but when it comes to drain cycle it wont drain all the water ,even onthe last cicle which is dry,will drain but water still remaing there, i’ve already replaced the timer but no success please help.
How much water is left in the dishwasher?
If it’s just about a 1/2’ above the grate in the back , then it’s normal. The dishwasher does not drain completely because the pump used water as a lubricant.
Here are the break down diagrams for the Whirlpool dishwasher Model DU800CWDB5
