Dishwaher not working heard pop from lower coil underneath dish rack
I started running the unit and went to add something. On the Lower right side I heard a pop. There is a coil like thing that runs in a square around the propeller on the bottom of the unit. The unit will not work
I was running unit and went to add something and on the lower left under the lower dish rack I heard a pop. the is a coil like thing that runs in a square around the propeller thing and now the unit will not run
