Dishrack manifold not lining up in rear
Brand: Samsung
Model Number: dw80f600uts
Main Symptom: Purchased a middle dishrack assembly DD82-01074A. After I transferred the old spray arm manifold from the old rack and installed, the rear port does not line up, its about 1 inch off, did I purchase the wrong dishrack assembly? Please advise
Thanks for sending the pictures. They help clarify the problem.
Looking at your side-by-side comparison, I can see that the new rack (left) and original rack (right) have different wire configurations around the rear manifold mounting area.
The first picture also shows the rear water supply connection inside the dishwasher.
Here’s what concerns me: The original spray arm manifold may physically attach to the replacement rack, but the mounting position appears to be different. That could explain why the water connection is approximately 1 inch out of alignment.
I would not force the connection or modify the rack to make it fit.
What I recommend
Before returning the rack, I’d like to verify two things:
  1. Does the new rack slide completely into the dishwasher without the manifold installed?
  2. When you transfer the original manifold to the new rack, is the rear connection too high or too low compared with the opening on the dishwasher’s rear wall?
Based on the pictures, I suspect a rack compatibility or mounting-position issue rather than a problem with the dishwasher itself.
Although DD82-01074A is listed as compatible with the DW80F600UTS, the pictures raise a legitimate question about whether this replacement has the correct mounting configuration for your original manifold.
If you can also provide the complete model number from the dishwasher label, including the /AA version number, we can narrow down whether a different rack assembly is needed.
I already attached a picture of the complete model number it is DW80F600UTS/AA.
The rack does slide completely into the dishwasher, the rear connection is too high (by about 1 inch)
Yeah the racks are different heights in your picture. My recommendation at this point is to reach out to customer service and see if they can replace it to see if it was a mis ship
