Dishes not clean anymore
Dishwasher used to clean great ,now dishes come out barely rinsed. Top sprayer not working , bottom and middle sprayer seem to rotate slow. Checked sprayers for blockage , looks ok. I can’t get out last screw on filter assembly to really see if there is any blockages in water well. The plastic water channel is directly above 1 screw. Any suggestions. Thanks
Here are the parts
Replacement parts for GU3600XTR models | AppliancePartsPros.com
Here is a manual which should help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/a045b97f9e505696852574ce0049f265/$FILE/8178741.pdf
I am not sure but if the above does not match your pump may be closer to the following
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/89d39c1d212f21eb85256ab000567fd2/$FILE/4317196.pdf
do you think it could be the pump even though it is pushing water? or do you think it could be some sort of blockage. thx.
[COLOR=“Blue”]do you think it could be the pump even though it is pushing water?[/COLOR]
Yes , could be the impeller is slipping on the motor’s shaft.
[COLOR=“Blue”]or do you think it could be some sort of blockage.[/COLOR]
Dirty filters etc. is the more common cause
