Kenmore dish washer, control panel lock came on and we can not get it to unlock so we can use the washer
Your advice will be most welcome,
The button sequence for childlock should be clear and present what to push on the touch pad if it is not push the heat/dry button for 10-20 seconds it should unlock it…if that don’t work try tripping your breaker and turning the power off to the unit for 5+ minutes…If that fails look under the bottom cover plate for a tech sheet or under main front panel there should be a white piece of paper showing you what to do or your manual will show you.
