Dish washer
Don’t heat the water or dry the dishes or clean very well.
Also has extra long cycle times.
Replacement parts for WHIRLPOOL KUDR01TJWH1 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Tech%20Sheet%20-%208533399.pdf
Since the unit does complete a cycle and you did not mention extra long cycle times I would suspect the thermistor. Check it with a meter.
The problem is that this does not explain why the dishes are not drying.
Could be that you have 2 problems.
Could also be the heater itself or the high limit thermostat but as mentioned above I would have thought you would see extra long cycle times.
Check them with a meter.
It does have extra long cycle times also.
Then it sounds like there is a problem in the heater circuit.
This should not be difficult to troubleshoot with a meter.
O.K. , Thanks Denman.
