Our Whirlpool Quiet Partner I, has not run complete cycles for quite a while, about a year age I ran the Diagnostics cycle a couple of times, and it seemed to work, Now however in the 1 hour mode it fills and washes, twice, then the green lights go out and the red drain/cancel LED lights up, with a loud relay noise, the unit drains then shuts off completely.. It fails the 6-1
in 1 hour mode the unit runs almost exactly 14 Minutes…![]()
Wayne,
I am having the exact same problem with my Quiet Partner 1 dishwasher. Have you had it repaired yet, or had anyone look into it? If so, what was the problem and how was it fixed?
Thanks,
SHS
