Water will fill bottom container, the start to pump through the outlet pump but stops within a few seconds.
Any ideas?
Any ideas?
Hi.
Did I get you correctly: the d/w fills up with water then starts draining and shots off?
Simon.
The machine will stop as dion as the pump
begins pumping water into the spray arm on
bottom. It will try to start after that but stops
at the same point once water is pumped into the
lower spray arm
