just replaced the main electronic board & tactile board the results were the clean light comes on, nothing else happens. If I press reset it beeps and the clean light goes on. I am unable to have anything else work. Is there another electronic switch that i need or did they send a part that does not match my machine?
thank you
Peter
Make sure all the electrical connections are secure, especially the ribbon connection between the user interface and the board.
[QUOTE=magician59;199083]Make sure all the electrical connections are secure, especially the ribbon connection between the user interface and the board.[/QUOTE]
did that,almost clicks into place
my question is if only the reset button works do i have the wrong equipment because no other commands work
