Dish washer problem
Brand: bosch
Model Number: shu43c05uc/14
Main Symptom: shuts off
What happens & when: shuts off
Hi J4252655, if your dishwasher is shutting off before the cycle finishes, the most common causes are a faulty door latch, a failed thermal fuse, or a defective control board. This model relies on several built-in electrical and mechanical safety features, so if the control detects that the door isn’t securely latched or an electrical fault is present, it will immediately shut the dishwasher down to help prevent water leaks or electrical damage.
I would recommend starting by checking the door latch to make sure it’s closing properly and staying engaged throughout the cycle. If the latch checks out, inspect the thermal fuse for continuity. If both components test good, the next step would be to diagnose the main control board, as it may be intermittently losing power or failing during the wash cycle.
