Dish washer flashing on normal cycle
Normal wash light just flash’s and when you press cancel and hold it in it stops as soon as you take your hand off it starts flashing again.
Mike
Hi Mike,
Most likely the problem is a stuck pad on the control panel. In order to fix it the console has to be replaced. I need the color of the control panel to provide the right part number.
