My new Bosch dish washer drains into the sink via a vent line (I think). It sets next to the knobs for the water. It has so much force that it gets the top of the counter wet.
Any ideas, the guy at Lowes said it maybe the vent part:confused:
Thanks for the help,
Is the water coming out the holes of the airgap “vent”. If so, you have an obstruction from the hose that goes from the “vent” to the garbage disposer and is causing the drain water to back up.
Yes it is coming from the holes of the airgap “vent” which is mounted on the sink. I have replaced the dishwasher, garbage disposal and the hose. Could it be the airgap "vent itself?
Thanks for your help,
Did you remove the plug in the garbage disposer where your drain line hooks too?
