Disassemble door latch switches
Recieved new part to replace broken handle on latch. Can not seem to disconnect the switches inside the panel in order to reattach new assembly. Please help
AP6015450
Click on the picture of the parts for more info about it.
Look at the connector to see if it has a small latch that has to be pushe to release the connector from the switches.
Wiggle the connector from side to side while trying to pull it off.
Sometimes inserting a flat blade screwdriver between the switch and the connector and then twisting the screwdriver will force the connector off.
