My Whirlpool Gold won’t heat the water on Normal cycle. I believe it is temperature regulated so it won’t complete the cycle. What do I check?
A model number may help others help you.
Unplug or remove power from the unit.
Check the heater for continuity, usually around 20 ohms.
Often there is a hi-limit or control thermostat wired in series with the heating element. It should be 0 ohms.
Thanks denman,
The model # is GU1500XTKT0 Whrilpool Gold and it’s about 9 years old.
Replacement parts for Whirlpool GU1500XTKT0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
See the attachment for the tech sheet. it has info on the heater resistance etc.
GTX1500.pdf (1.1 MB)
