Diagnostic code
There are several touchpads (delay, china)on the keypad that seem inop. Is there a code to enter to place the machine in diagnostic mode, so I can see if it is the keypad or the control unit that is the problem? Thanks.
Replacement parts for Whirlpool GU940SCGZ2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Unfortunately there is not a diagnostic, also this unit does not have a pin-out for the key pad so you cannot check it. The problem can be either the control panel (keypad) or the control board. It is a crap shoot as to which is the problem but I would replace the control panel (keypad) first.
Usually a keypad will have a common line for a number of keys so if that line opens you loose several keys.
I would give the following a try before ordering anything.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
GU940.pdf (471.7 KB)
