My symptoms are related to water power so I’m leaning towards replacing the motor but I was hoping someone here could verify or suggest other things to check.
Basically, the symptom is that items in the top-rack are no longer getting cleaned whereas items in the bottom still are. Also, the detergent dispenser always has soap left in it which also leads me to believe it is a power issue.
