The element on my Dual Fuel (Electric) Oven is no longer heating at all. In addition, the Red indicator light will not illuminate. When I do place it into Bake mode, I can hear it ‘clicking’ (normal) as it tries to raise the heat.
- On ‘Bake’ setting, the upper (broil) element heats (and the broil function works just fine)
- I removed/checked the element with a multimeter and it has continuity
- I removed/checked the thermal fuse with a multimeter and it has continuity
- My guess is that the only other problem is a blown logic board (which I can get fixed by a refurbisher)
My question is whether there are other common faults that could cause this problem before I remove the board and send it off for a couple of weeks
Although it is a downdraft model, I can disconnect the conduit below easily to access the oven/pull it out.
New to the forum - any help/advice appreciated.
Thanks in advance.
