Diagnose washer
Brand: Estate
Model Number: Taws750pq0
Main Symptom: water won’t stop, water won’t drain???
What happens & when: replaced timer, water inlet valve, water level switch.
Parts or tests already tried: timer, water inlet valve, water level switch
Hello, we will need a little more information. Does it drain the water out or not? Does it put too much water in and overflow the tub? If you can give us more information, we should be able to help.
no water won’t drain out.
yes it puts too much in tub on any level
Are you still there?
If your water will not drain out and the drain pump motor is running, either there is a restriction in the drain system, or the impeller is bad. If the motor does not come on to drain out the water, either there is no voltage going to the motor, or the pump motor is bad.
