Determining F1 Error Code
Kenmore Elite: As washer begins to fill with water during both wash cycle and rinse cycle, F1 always appear at least twice. I press stop and start each time before cycles continue. What does F1 mean, and how can I rectify the problem?
If you will post a model number someone may be able to help you.
[QUOTE=sidfink43;576971]If you will post a model number someone may be able to help you.
Thanks[/QUOTE]
What an answer, some options would have been better Senior expert???
