Delayed Gas Flow
Ignighters work well. Takes up to 5 minutes for gas to start flowing (have trued with all burners) Once one burner lights gas flows quickly to light others. IS this a regulator issue or is there a safety valve that needs replaced?
Most likely the problem is a bad gas pressure regulator.
Here are the break down diagrams for the GE stove Model JGP328BEC1BB
