Hello - my refr/freezer stopped cooling. We were told by a local tech that the Defrost Timer was stuck, and should be replaced. However, after finding the part number on it (TMDG823VB9), I have not been able to locate a replacement. If I can’t find the exact part, can I swap it out for a part with the same specs? 120 VAC, SW1-2 125 VAC 10a, SW1-4 125 VAC 1/3 HP. Much Thanks — Jeff
Montgomery Ward, Signature 2000 by Admiral, HMG 19804
