My coils in the freezer keep freezing over and the fridge gets warm. I want to test my defrost timer but cant find it. A paper I found that came with the unit said it is under the left side by the toe plate. It isnt. Looked on back of unit and nothing. Took a panel off that covered the coils in the freezer didnt see it there either.
Replacement parts for FRIGIDAIRE FRS22XGCW0 Frg(v2) / Side By Side Refrigerator | AppliancePartsPros.com
It shows the timer is in the control module at the top of the fresh food section Item 23A in Section 5.
There is usually a hole to let you manually turn the timer cam.
So the fresh food section that would be in the fridge side then.
Yes, take a look at the parts breakdown and it will give you the approximate location♦
Yep I see that now thank you
