The defrost thermostat was replaced at 4 yrs. old. It appears to need replacement again (4-5 yrs. later). Should the defrost thermostat be properly placed on the evap. coil end that is the supply from the condensor or the return end. Presumably the coil end at the back, which gets cold first, is the supply side from the condensor. Thanks.
Replacement parts for AMANA DRS2362AC Ref - SXS/I&W | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/T13063R1.pdf
Here is a manual
See pages 26 and 41 in the manualfor thermostat placement.
You may be jumping the gun unless you have troubleshot it so you know that the thermostat is the culprit.
Thanks Denman. Could you possibly send the manual again. I think you sent two copies of the Tech Bulletin. Thanks, Mark
Sorry about that
Here it is
http://www.servicematters.com/maytag_library/docs/S130_4R1.pdf
Many thanks.
