Defrost system isnt work. Help please!
Hey all, my refrigerator is not cooling and i have ice build up on my coils i have trouble shot it to the defrost system but havent a clue as how to proceed with tracking down which part it is. Any help would be greatly appreciate, getting kind of tired of having to defrost the freezer every couple of days. My model number is frs3hr35kb Frigidaire. I also cant find the defrost timer, just the defrost therm, heater coil and the defrost switch, so havent a clue as to how to begin trouble shooting the system. Thanks again for any help!
Your model number seems to be missing the last digit.
There are KB0 to KB4 models. I sued the KB2 model.
They are probably very close if not an exact match.
Hewre are your parts.
Parts for Frigidaire FRS3HR35KB2 Refrigerator - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389636.pdf
I do not know what the defrost switch is, could you please provide more info.
Your unit does not use a defrost timer it uses an adaptive defrost control board (item 23 in the Controls Parts section).
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If yes.
Manually force a defrost cycle, see the tech sheet When the fans and compressor turn off, you are in a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, as it is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in System Parts Section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 21 in System Parts Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Thank you for all the information! I will let you know how it turns out.
Ok i said i would let you know when i was finished. I know i am not the first for this to happen to but i am probably one of the first to admit it. After reading the post i got to work on trouble shooting the system thanks to the reply i got.. So i let the freezer build up a little ice then i clicked the light switch to turn on the defrost.. The heating element never got hot… So downstairs i went for my multimeter and back upstairs to the fridge… Putting a towel on the floor because i am old and i needed the padding for my knees i knelt down and proceeded to unhook the negative wire from the heating element then to the positive side… I barely touched it and it disconnected pretty much by itself… Yep, in my hast to fix the fridge and be the hero in my house i never checked the wires to make sure they were solidly connected… After reconnecting the wire… As if the element touched the Sun it heated up like no ones business… My cold box is fixed… Moral of the story.. Check the wires to make sure all are connected!
