The 106 tells us that Whirlpool made this unit.
Replacement parts for KENMORE 10674264400 | AppliancePartsPros.com
OK looks like they have replaced the adaptive defrost board and the evaporator (freezer) fan.
Your porblem could be the defrost system and perhaps the temperature thermostat.
To check the thermostat the next time it happens turn the main thermostat slightly left/right, do not turn it to off. If the unit fires up then the thermostat is probably sticking open.
For the defrost check, please see below.
[COLOR=“DarkRed”]It is my understanding that the automatic defrost is there to prevent ICE build-up in the freezer[/COLOR]
Strictly speaking defrost does not remove the ice in the freezer, it removes the ice/frost build up from the evaporator coils in the freezer.
They way it works is that the adaptive defrost monitors the fridge usage and then determines how often the unit should defrost. It then starts then defrost in this case it looks like it is 18 minutes for this unit. This is a fixed time. There is a defrost thermostat clipped onto the evaporator coils, this thermostat opens just above freezing. So if all the ice/frost has melted off the coils before the 18 minutes is up it shuts off power to the defrost heater.
[COLOR=“DarkRed”]When the refridgerator is completely silent, the freezer termp is above freezing. We’re assuming that when the refridgerator is silent that it is in defrost mode.[/COLOR]
Yes when the fans and compressor is off the unit is usually in a defrost mode.
Though some units do shut off the fans when the thermostat is open turning the compressor off.
When it is running correctly turn the main temperature thermostat down to see if the compressor and the fans all shut off.
[COLOR=“DarkRed”]
The refridgerator makes a grinding noise that we think is the fan hitting the ice build-up behind the freezer. We’ve actually turned off the refridgerator to allow the ice to melt.[/COLOR]
This does sound like a defrost problem.
It sounds like the defrost may be intermittent, usually a defrost problem will not clear itself and you have to do a manual defrost to get the unit working again.
Try to force a defrost (see the tech sheet)
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle, see the tech sheet till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the adaptive defrost board needs replacing, re: it is never getting into a defrost cycle.
I would also check the defrost thermostat for bulging as it is often the cause of intermittent defrost.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
74264400.pdf (505.5 KB)
