I am following up my post with the correct model# for my GE Fridge. I incorrectly stated that the model# was Cts201cncww, it is Gts201cncww
thanks: billkenny
Remove the 2 screws at the bottom of the air tower in freezer, slide air tower up and off, remove foam air divertor by pulling up, if it’s frozen don’t force it or it will break…remove the screws in the top left and right of back panel. now remove the 2 screws in the center and pull the back panel off and remove from freezer. below the evap in the center is your drain hole, use a turkey baster and hot water to clear the hole, it may take a while. You’ll know when the drain is unclogged
Thanks for your quick reply but the problem is that I don’t see any screws at the bottom of the air tower. In fact I don’t see any screws on the back panel of the freezer at all. Does the back panel pop out somehow? This is getting to be a real quandry. again the model# is Gts201cncww. thanks for any further help you can give me.
If I’m looking at the diagram correctly, the drain is at the back of the refer, look back there, looks like there is a tube and grommet assy back there. let me know
[QUOTE=abadfish66;23468]If I’m looking at the diagram correctly, the drain is at the back of the refer, look back there, looks like there is a tube and grommet assy back there. let me know[/QUOTE]
There is a cover inside the refridgerator compartment that attaches to the bottom of the freezer compartment. The ref temp control is toward the front of this cover. On the back of the exterior there is nothing up high, but at the bottom there is drain tube and pan underneath where the compressor is located.
billkenny,
You have to remove the evaporator cover in the freezer, not in the refrigerator. The drain hole is located under the evaporator coil.
I would recommend to use a hair dryer to defrost the drain first and then you can use a turkey baster and hot water to clear the drain as recommended by abadfish66.
Hi Gene
Thanks for your reply to my problem of the clogged defrost drain. My quandry is that there ar no visible screws in the freezer compartment. So, how do I get at the defrost drain
There should be something holding the panel in place. We are not able to give you more accurate information without seeing the fridge.
Not to dig up an old thread, but I thought this info might be useful. To get to the drain you have to take out the ice maker, back off the 2 screws and lift the assembly off then unplug the electrical connector. Then pop off the plastic button to expose a screw, remove it and that plate should pop right off. The whole back panel (which just clips in) pops off from the top side first exposing the drain, in my case was a solid block of ice, the drain will be in there somewhere.
bohawk: Just a quick note to thank you for refreshing that old thread. Got stuck right at the step where you identified how to remove the fascia (GE GTS201 refrigerator). Got it off and was able to find the drain and defrost it. Many, many thanks.
We had the same problem with a similar fridge, and no clue what to do. This info saved a lot of headache, thanks so much!![]()
[QUOTE=bc-sf-arch;184516]bohawk: Just a quick note to thank you for refreshing that old thread. Got stuck right at the step where you identified how to remove the fascia (GE GTS201 refrigerator). Got it off and was able to find the drain and defrost it. Many, many thanks.[/QUOTE]
here it is… YEARS later, i found this post for the GTS20ICNCCC to help with my freezer drain! I just wanted to express my gratitude! I would not have been able to do it on my own without you guys! Thank you so much! Sincerely, Lori.
I have this same fridge with no apparent screws in the back. Thanks for the tip on the hidden location of the ONE screw behind the ice maker! However, I’ve still got an issue. My drain was a solid block of ice, took an hour with alternating hair dryer and hot water to finally break it loose. About 15 minutes before it finally thawed through the ice blockage, MORE water started running into the fridge. It is as if the drain tube is cracked. The effect is, my drain is now unplugged, completely clear but water is still running into the fridge! There is water coming out the drain tube AND also draining into the fridge. As far as I can tell the drain tube is actually rubber and is flexible. Perhaps the rubber got old and couldn’t take the expansion of the ice…
leeloo67,
It was at least two different models discussed in this thread. Please, post the complete model number of your refrigerator.
Model is ge gts201cncww.
It has been a couple of days now and the continuing water is extremely puzzling.
My best guess at the time of initial repair attempt a few days ago was that the top of the drain pipe had a crack in it. As best I can tell there is no serviceable way to access this drain pipe in order to repair or replace. My idea was to insert a rubber or plastic tube down the top of the drain to “seal” any leaks. So I took the inside rear of the freezer off again and to my surprise, at that particular moment - despite water actively dripping down into the fridge from somewhere - there was no water going down the top of the defrost drain tube at that moment!
So at this point I surmised there must be built up ice somewhere that is slowly melting. I followed the dripping water up the back of the fridge, along the center shelf bracket. There is a thin stream/drip coming right down the center of the bracket. It seems to be coming out of the very top screw.
Over the ensuing days the water seems to have slowed and volume decreased. For example over the past eight hours there has been not a single drop. Then I heard a “CRACK” sound from the fridge and there’s an active stream of water coming out of that bracket screw! Not as much water as before, but I could see a puddle forming.
I pulled the fridge out and the defrost drain tube is still clear, there is water still coming down the tube. Oh and I’ve also shut off the ice maker and the water supply just to rule that out.
Usually google will turn up some ideas but there is literally nothing out there regarding a persistent drip AFTER clearing the drain tube. Everything points to a plugged drain tube but it is not. I can pour water down and it flows out the bottom just fine. And yet there is still water dripping into the fridge. Very puzzling. I’m sticking with the ice block theory for a few more days. Then may have to just get a new fridge. I have to move on with my life at some point!
